Which springs 918 or ls6
Old Feb 4, 2005 | 06:17 AM
Default Which springs 918 or ls6
Just picked up a comp 206/212 515/522 and need to get a set of springs for it. Which would be better the 918 or ls6. I figure for the lift it has and I am using stock rockers the ls6 should be just fine for me. Where is the cheapest place to get a set of ls6's at.
Old Feb 4, 2005 | 11:58 AM
budhayes3's Avatar
PT's Slowest Truck
You should be fine with the LS6 springs...I have that same cam, except on a 114 LSA, and I'm using Comp 916's, as per a Comp Cams rep's recommendation.
Old Feb 4, 2005 | 12:23 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I'd try the classified section (Parts for Sale, not truck classifieds) and see if you can find a set of LS6 springs. I bought a cam and springs a year ago for around $100.
Old Feb 4, 2005 | 04:24 PM
ktmrider's Avatar
Yep, LS6 will be fine IMHO too. In fact, either the 01 ( .525/blue ) or 02+ ( .550/green ) will work, I would go with the 02+ in case you upgrade cams later.
Old Feb 4, 2005 | 11:18 PM
SimpleManLance's Avatar
is the .525, and the .550 the lift that they are good to. because my buddy just bought the green ones off e-bay and he has a .525/.532 lift on the cam and he also has 1.85 rockers that he is putting on.
Old Feb 5, 2005 | 03:05 PM
to the top
Old Feb 5, 2005 | 05:31 PM
99Silver6.0's Avatar
Originally Posted by TheLadiesMan
to the top
My green 02's are good to .550 lift. The springs your bud got aint gonna cut it with the rockers on. Gonna get coil bind if he trys them with the rockers.
Old Feb 5, 2005 | 05:57 PM
Hey 99silver5.4, didn't you get a new cam for your truck? got it in yet?
Old Feb 5, 2005 | 05:59 PM
one03sierra's Avatar
Formerly one92rs
Talking
ladiesman. if the cam you are refferring to is the old one i use to have with those rockers then 915 minmum will be needed. with the 525-532 and the 1.85 rockers the lift will be more than 550 lift and will cause float at a higher rpm.
Old Feb 5, 2005 | 07:50 PM
desTRUCKtive's Avatar
what do you guys mean by blue or green. do the springs come color coded or what. So the greens are good till a .550 lift?
