Spraying with ET Streets
Old Sep 30, 2002 | 04:49 PM
RODNEY's Avatar
Default Spraying with ET Streets
Is any body spraying with a stock converter and some ET STREETS, Also have a 3.73 pos. What is the most i can spray out the hole? I have only one stage NX kit. Running 8.50's now on my every day street tires, with a 125 shot. I just got some WELD RIMS 15 by 10's and 30x12.5 ET STREETS.
02 CHEV. SB REG. CAB
I know i will have to do some grinding
Old Sep 30, 2002 | 07:23 PM
11 Second Club
Default Re: Spraying with ET Streets
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by RODNEY:
<strong>Is any body spraying with a stock converter and some ET STREETS, Also have a 3.73 pos. What is the most i can spray out the hole? I have only one stage NX kit. Running 8.50's now on my every day street tires, with a 125 shot. I just got some WELD RIMS 15 by 10's and 30x12.5 ET STREETS.
I know i will have to do some grinding</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Those are some big *** tires, they will hook with any shot. Are you spraying below 2500 RPM.
<small>[ September 30, 2002, 07:25 PM: Message edited by: work in progress ]</small>
Old Sep 30, 2002 | 07:28 PM
parish8's Avatar
single digit dreamer
seems like i heard 15" rims wont fit these trucks
Old Sep 30, 2002 | 07:48 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by parish8:
<strong>seems like i heard 15" rims wont fit these trucks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">not unless you grind the brake calipers.
Old Sep 30, 2002 | 08:17 PM
I had 16 inch ET streets on my truck and sprayed it out of the whole with a stock converter...It hauls *** but the cylinder pressure sure get high, and then after a few months of hard spraying means Kabooooooommmmmmmm....But it will haul *** if you do it right...With a small shot i would not worry about it to much....
Old Sep 30, 2002 | 09:25 PM
GREGGO's Avatar
I was gonna use Hyde's example, but I see he posted up. IMO, the pistons and internals in these engines suck and won't hold up long under heavy use. You can spray out of the hole, but I recommend above 2800. That's just my opinion though. You are talking wet shot aren't you?
Greg
Old Sep 30, 2002 | 10:39 PM
BigTex's Avatar
It wont be easy getting 15" wheels to fit. It really depends on the wheel itself, and the internal diameter. I tried a set of 16" stock aluminum wheels off a pre 99 4x4. I couldn't get them on even after grinding and using 3/4 wheel spacers. But then I found a late 80s 16" GM steel wheel that fit. So who knows.
Old Oct 1, 2002 | 07:39 PM
hyper's Avatar
hyde what are u considering a small shot?
Old Oct 1, 2002 | 08:41 PM
GREGGO's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by hyperlite:
<strong>hyde what are u considering a small shot?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">His idea of a small shot is 125 or under.
Greg
Old Oct 1, 2002 | 08:50 PM
Yes Gregory that would be correct....When are you going to come and hang out and look at my new project?
<img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
