Spraying dry kit?
Old Jun 7, 2002 | 10:30 PM
StreetSweepa's Avatar
Default Spraying dry kit?
If i'm spraying a dry nitrous, do i want to spray it in front of the MAF Sensor or behind it? Why?
Old Jun 7, 2002 | 10:45 PM
oxidizr's Avatar
Moderator / Sponsor
Default Re: Spraying dry kit?
You can do either but it depends on what kind of dry nitrous are you running:
If you are simply spraying nitrous and have no means of fuel compensation you MUST spray before the MAF so the computer can calculate and add the appropriate level of fuel.
If you are spraying nitrous and are boosting fuel (via some sort of pressure or flow devise) then you MUST spray after the MAF.
An incorrect location with respect to which type of system you have can lead to catestrophic engine failure. Give me a better idea of your system layout and I can make a more educated recommendation.
Richard
Old Jun 7, 2002 | 11:04 PM
Well, right now i'm pretty much stock except for exhaust and a few free mods. Would i be alright running a 100 shot in front of the MAF Sensor even. I don't have any fuel compensation.
thanks
Old Jun 8, 2002 | 01:59 AM
Listen to Richard.....h e seems to be the N20 god in the truck section.
ps- Richard, i went to your site, i love your juice set up, looks damn cool. How much were the Caltracks????? And were did you get the Diff cover?
Old Jun 8, 2002 | 03:13 AM
1999stepside's Avatar
Hey Richard, how do you link your web page in your sig? Thanks, Kent.
Old Jun 8, 2002 | 03:56 PM
oxidizr's Avatar
Moderator / Sponsor
CalTracs are about $300 and the differential cover is from Tom's Rears...its a T/A performance cover for a 8.5" 10 bolt rear.
mine:
{url=http://home.earthlink.net/~rwaitas}01 SCSB Chevy Silverado{/url}
format:
{url=http://www.yourwebsite.com}What ever you want to call your link{/url}
be sure to replace the "{"&"}" with "["&"]" to make the UBB recognise your commands.
Richard
Old Jun 9, 2002 | 12:06 AM
Thanks, Kent.
<small>[ June 09, 2002, 12:09 AM: Message edited by: 1999stepside ]</small>
Old Jun 9, 2002 | 12:23 AM
Brandon Boomhauer's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by oxidizr:
<strong>CalTracs are about $300 and the differential cover is from Tom's Rears...its a T/A performance cover for a 8.5" 10 bolt rear.
Richard</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i thought we had a 8.6
or does it not matter?
Old Jun 9, 2002 | 03:23 AM
oxidizr's Avatar
Moderator / Sponsor
You are correct but the 8.5" is interchangable.
Richard
Old Jun 9, 2002 | 10:16 AM
are the gears for a 8.5 interchangable also?
mhotrodscooter
Aug 23, 2015 04:41 PM
urdone
Aug 18, 2015 12:17 PM
jroctpb
Aug 11, 2015 03:52 PM
sprayed99
Aug 4, 2015 09:09 PM
vmaxpro
Jul 27, 2015 10:45 PM
