Speed Engineering True Dual Exhaust Prototype..
#831
Rear exit kit may be quieter than the dumped version but I'd never call it quiet! I honestly couldn't imagine a louder exhaust. Ear plugs needed for towing camper any further than across town.
So far I've added cats back to the system. Improved idle volume. Still not neighbor friendly. Replaced the mufflers with magnaflow 5x8x24. Don't feel bad when starting tuck in mornings anymore. Good reduction but 1600-2k drone is still exhausting. Was able to survive 1800 mile fishing trip to Canada with this setup. Never thought I'd appreciate 4.10s and 80e overdrive ratio on a long trip, higher rpms were a blessing. Next was vibrant resonators in front of mufflers. Getting closer but still far from quiet. Towing is still brutal at lower engine speeds.
May swap the 5x8x24 for the 5x11x22 magnaflow leaving the vibrant resonators or screw around with jpipes or both. Have bends purchased just not sure how I'll cope the pipes.
#832
If it's too loud I'll add a resonator or 2 lol. Let me know if anyone has suggestions on a resonator. I'm excited to install the new exhaust. Speed engineering makes good stuff.
#833
this is going to sound good but....
I ordered the 1 7/8 long tubes and ory. I'll keep my stock catback with 40 series Flowmaster (both exit pipes sawzalled 4" after muffler. I'm sure it'll be loud. I wish I had a recording of it before so I could compare.
#834
Be prepared to get a tune you are going to loose bottom end umpfh. You are going to gain more power in higher rpms but lose some in lower rpms. I would highly recommend adapting your cats to speed engineering y pipe. Also be sure to get v band clamps from jegs at $8.00 each. The clamps that come with it suck and leak. Also get a ratchet strap and pull the ypipe together then tighten clamps. I had a hell of a time getting a leak free exhaust. The true duals kit is far more reliable as far as leaks goes.
Thanks tpartsman, I used the ratchet strap that helped a lot. I should have bought the v band clamps but I ran out of time. I had to get it all bolted up so I could fire up the new motor. I would have gladly paid SE for good clamps.
I have heard mixed results about using RTV in these slip fittings. Any thoughts?
#837
Sensor safe rtv
#838
SE guys are great
Every time I call they answer and help me out. I called to ask if I could buy parts to build my own 3" single cat back because my original plan isn't working out like I hoped. They made some suggestions and told me some options that I hadn't considered.
Thanks guys!
Thanks guys!
