Spark Plug Wires?
Old Oct 16, 2004 | 10:59 AM
4.8redchev's Avatar
Default Spark Plug Wires?
Im wondering if its worth it? i know i wont see any gains out of this but is it a good mod? or should i look for somethin else? would a 160 degree thermostat go good with my hypertech? i have about $500 and i want to spend it wisely
Old Oct 16, 2004 | 11:31 AM
2k5Squirrel's Avatar
14 Second Truck Club
I'll take $500 for my Nitrous Kit, it'll drop you over 1 sec. in the 1/4 mile. I acutally went from a 15.7 to a 13.9 w/ a 125 shot and Nelson tune. I will even help you install it.
Conrad
ZEX Wet Kit P/N 82023 75/100/125/150 H.P.
Old Oct 16, 2004 | 02:28 PM
i have 160 degree thermostae in my truck, and jba 9mm wires, 50 bucks for wires 45 for stat. i have a stAt for sale 160 hypertech power stat. i have 2001 4.8 silverado.
Old Oct 16, 2004 | 02:50 PM
Mr. Sandog's Avatar
After lots of research I decided to stick with the stock wires. Too many quality issues with aftermarket wires, and no demonstrable gain even when they weren't defective. I am, however, switching to NGK plugs.
Old Oct 16, 2004 | 04:55 PM
4.8redchev's Avatar
[QUOTE=BIG VINCE]i have 160 degree thermostae in my truck, and jba 9mm wires, 50 bucks for wires 45 for stat. i have a stAt for sale 160 hypertech power stat. i have 2001 4.8 silverado.[/QU
how much cooler did your truck run? also does it acutally help with the HPP3 if you can tune it with the 160 degree thermostat?
Old Oct 16, 2004 | 04:57 PM
4.8redchev's Avatar
how much cooler does your truck run with the 160 in? can i tune my HPP3 with that? because it ask's if i have installed one
Old Oct 16, 2004 | 05:05 PM
v8
17,16,15,14,13,12,11 Drvr
yes the hpp3 will work with the 160 stat
Old Oct 16, 2004 | 06:43 PM
4.8redchev's Avatar
what does it do with the hpp3? does it make it alot cooler or what? im confused on why in the programmer it would ask if i have installed a 160 thermostat
Old Oct 18, 2004 | 09:21 AM
marc_w's Avatar
Tip-in and low-throttle-opening throttle-responce should be improved with a set of wires. It was in the last two GenIII trucks I put wires in...
Old Oct 18, 2004 | 01:04 PM
Mr. Sandog's Avatar
Which MSD wires did you get?
