Spark Plug Wires?
Im wondering if its worth it? i know i wont see any gains out of this but is it a good mod? or should i look for somethin else? would a 160 degree thermostat go good with my hypertech? i have about $500 and i want to spend it wisely
I'll take $500 for my Nitrous Kit, it'll drop you over 1 sec. in the 1/4 mile. I acutally went from a 15.7 to a 13.9 w/ a 125 shot and Nelson tune. I will even help you install it.
Conrad ZEX Wet Kit P/N 82023 75/100/125/150 H.P. |
After lots of research I decided to stick with the stock wires. Too many quality issues with aftermarket wires, and no demonstrable gain even when they weren't defective. I am, however, switching to NGK plugs.
[QUOTE=BIG VINCE]i have 160 degree thermostae in my truck, and jba 9mm wires, 50 bucks for wires 45 for stat. i have a stAt for sale 160 hypertech power stat. i have 2001 4.8 silverado.[/QU
how much cooler did your truck run? also does it acutally help with the HPP3 if you can tune it with the 160 degree thermostat? |
yes the hpp3 will work with the 160 stat
Tip-in and low-throttle-opening throttle-responce should be improved with a set of wires. It was in the last two GenIII trucks I put wires in...
