spark plug analysis
Old May 6, 2005 | 04:08 PM
OrlandoFL4.8's Avatar
Default spark plug analysis
Trucks been running really sluggish N/A, especially if I just miss the downshift from 3rd to 1st at a little over 35 mph, it would bog down at 3rd gear for a second or two before dropping to 2nd and fall flat on its face. I had the NGK TR6 gapped at .035 installed and ran about 15 bottles of nitrous before I changed them today. I now have the ngk tr55 gapped at .045 and it runs a lot better with new wires as well. Can anyone tell by the picture of the spark plug if the engine is running properly?
Old May 6, 2005 | 04:57 PM
Green Thunder's Avatar
Gonna need a better pic! Cant tell by that one.. If you are going to continue to spray Nitrous I'd put a set of TR6's back in and not use the 55's with the nitrous!
Old May 6, 2005 | 05:19 PM
I havnt sprayed with the ngk tr55, but have heard that some are using those plugs with nitrous. I understand the need to have a colder plug, but it just seemed that the truck ran sluggish N/A. Im running 93 octane and I have a small gap, ill spray and see what happens, if I get detonation ill back the timing down a little and try again and also Ill check the plugs after a few sprays to see how they are doing. Is anyone else using the 55's with nitrous? Sorry about the bad pick, that was the best I could do with my cheap camera, the old plugs seem to have a lot of black carbon at the very ends.
Old May 6, 2005 | 05:23 PM
The truck will definately run better N/A with the 55's..
Old May 6, 2005 | 07:25 PM
Hey Flipper, I was just browsing the pictures and information on your truck, that is a really nice set up you got there. Who would ever expect a crew cab to be equiped like that How much nitrous are you running, do you have any numbers, Ill bet that truck hauls!!
Old May 6, 2005 | 07:33 PM
THANKS!
Ive been working my way through the bugs and adjustments had a few set backs that delayed me almost a month, but I am up and running again and hope to be spittin some numbers out soon...
Direct port is 200hp right now..
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
