Some weight reduction
Old May 29, 2010 | 08:07 AM
04SilveradoMykk's Avatar
Default Some weight reduction
Hey Guys,
While the truck is tore down awaiting the arrival of the PerformaBuilt lvl 2 4L60E, I decided to change a few other things up as well.
Extra parts:
Fuel cell:
I even adapted the trucks original fuel level sending unit to work inside the cell.
Waiting for a transmission, and than to rebuild the dual exhaust. This time without running the drivers bank over to the passenger side.
I'll also be cleaning up & cutting off extra brackets and pieces not in use under the frame.
Cheers ~Mykk
Old May 29, 2010 | 08:15 AM
03chevyroyce's Avatar
what is your motor setup?
Old May 29, 2010 | 08:22 AM
Mighty Demon 825cfm double pumper
Super Victor copy single plane intake
Patriot 'Vortec' iron heads, 185cc Int runners, 63cc chambers 2.02"/1.6" valves
Comp XR276HR-10 cam, magnum 1.52 rockers, 26918 beehive springs
.040" over 350ci, H345NCP flat top pistons, ZZ4 rotating assembly, balanced
10.7:1 static compression, 8.6:1 dynamic
Old May 29, 2010 | 04:47 PM
The cell is mounted, I've got a question however. The sump has two -8 fittings, obviously one will be used for the fuel feed to the pump. Can I use the other for the fuel pressure regulator return?
Old May 29, 2010 | 09:32 PM
05RST2NV's Avatar
Very nice, keep us updated, i plan on puttin a fuel cell in real soon as well. What gallon fuel cell is that?
Old May 29, 2010 | 10:13 PM
It's a 20gal cell, wich looks funny to me because it's a 1/3rd the size of the trucks original 26 gal tank.
Old May 30, 2010 | 12:01 AM
05RST2NV's Avatar
Lol thats true cuz i wouldnt have figured it was a 20gal
dlt76028's Avatar
So you have an older vortec 350 in an 2004? Why did you do that instead of the ls engine?
Old May 30, 2010 | 01:09 AM
max1's Avatar
Banned
Originally Posted by dlt76028
so you have an older vortec 350 in an 2004? Why did you do that instead of the ls engine?
x-2..
Old May 30, 2010 | 07:14 AM
blown02408's Avatar
02 w/ lowest mileage 2800
I guess you don't have to take your truck to an emission test every two year like me
