Solved my overheating problem
Old May 30, 2008 | 08:21 PM
67SS509's Avatar
10 Second Truck Club
Default Solved my overheating problem
Had my 34" radiator with a single flue recored to a double. This cooled mine down a ton. The single flue just can't handle 400+ cubic inches. Also put one in a friend's truck with a stroker 402. At first his still ran hot (205*+) even with a 180* stat. I checked the stat in a pot of water on the stove and found it was not coming off seat till 200*. Installed another one and it idles at 174* and drops to 165* when you increase rpm's. And this is in the heat of the day. This says our water pumps are a little lazy at 750 rpm but can do the job when the rpm's are increased. If I can cool my 427 with 12.5 compression then this setup should handle most trucks on here. Here is a pic of the old and new radiator core compared. Also had to trim a little off the electric fans shroud to clear the extra thick core.
Old May 30, 2008 | 08:24 PM
MikeGyver's Avatar
I have never heard the term "flue" used like that.
Old Jul 12, 2008 | 07:08 PM
Llaverito's Avatar
Were did you get that done? With this heat we have over here Im having trouble keeping my truck cool even with 06 fans and electric water pump.
Old Jul 12, 2008 | 09:46 PM
phasemaster1's Avatar
Yeah where and how much?
Old Jul 13, 2008 | 01:08 AM
rgvsierra's Avatar
big difference.
i guess my 408 isint as wild, but i never have overheating problems with a stock 34 rad and oem fans.
Old Jul 13, 2008 | 09:07 AM
budhayes3's Avatar
PT's Slowest Truck
I like the looks of that 2 core radiator, very nice
Old Jul 13, 2008 | 11:10 AM
Stoichiometric's Avatar
That's pretty cool, pun intended. What type of coolant are you running? Stock size balancer?
Old Jul 13, 2008 | 12:00 PM
67SS509's Avatar
If anyone is interested I can get them one for $325+shipping. Brand new including the tanks with oil cooler and transmission cooler.
Old Jul 13, 2008 | 12:02 PM
67SS509's Avatar
I'm still running the orange stuff from stupidity but will be switching over to the green soon.
Running an ATI balancer with 10% reduction.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
