so yea, cam swap time
Old Mar 1, 2006 | 01:50 PM
Coban's Avatar
Default so yea, cam swap time
Im not really sure if I will have to replace the gaskets seeing as how it only has 40k on it.
Cam is the Comp 212/218 .558 .563 Hi-Lift Version.
From searches I've learned that the stock pushrods will be fine, but will I need to swap the srpings for some z06 springs or something better?
I would like to spin it to 6400 so keep that in your consideration.
The tools will be taken care of I think. I will also probably get a few extra spring locks just in case. And of course oil and antifreeze.
Anything else???
Old Mar 1, 2006 | 02:05 PM
FILE's Avatar
That cam will pull slightly higher. Consider shifting at 6600rpm.
Old Mar 1, 2006 | 02:43 PM
Coban's Avatar
well thats good news, will the stock pushrods and zo6 springs still work with that?
Old Mar 1, 2006 | 02:49 PM
FILE's Avatar
I would not recommend shifting @ 6600 with stock pushrods. Get a set of hardened ones. They run about $70 used.
Old Mar 1, 2006 | 02:54 PM
Yelo's Avatar
6600rpms ??, with a 212/218 ??....ok
I'd be leaning towards a 6200rpm shift with that cam but if it'll make power that high go for it.............
Old Mar 1, 2006 | 03:08 PM
Coban's Avatar
Thats more along the lines of what I was thinking.
Old Mar 1, 2006 | 03:43 PM
98TAauto's Avatar
6000-6200 shift is what my 210/218 is set for
but definitly get some different pushrods since they are so easy to swap lol
Old Mar 1, 2006 | 05:37 PM
FILE's Avatar
I am under the impression he is talking abuot the XR265HR cam. The complete specs on this cam are 212/218 558/563 115
I have tuned this cam before and it pulls nicely to 6700. Moreover, according to comp cams, it's operating range is from 1400-6700.
http://www.compcams.com/Technical/Cu...ML/200-203.asp
Furthermore, I currently have a 212/218 522/529 114 and ran my best time shifting at 6500.
You should be fine shifting at 6600-6700 with this cam.
Old Mar 1, 2006 | 06:00 PM
FarmerBeau's Avatar
Sexy Party Mod
If you are gonna spin the motor anywhere past 6000 rmp, I would get hardened pushrods and go with a more stout spring like at least a Comp 915, (which you can get fairly cheap) but i would run 918s just to be safe.
Old Mar 1, 2006 | 06:15 PM
ap2002's Avatar
do it right the first time, get you some 918 springs and some hardened pushrods.... pm me and I'll give you a number where you can buy them the cheapest here in houston.... I am no cam expert but I agree with Tiburon, I think if you get teh hardened pushrods and 918springs, you should be able to shift at 6500-6700??
