So I've got an air leak somewhere
Old Apr 26, 2009 | 09:58 PM
  #31
dc_justin's Avatar
Hello Dave
Originally Posted by GMCtrk
Hi Justin,
As per your instructions, I disabled the MAF and I did not notice a difference in how it drove. It was however commanding max line pressure, so I didn't go WOT. I don't want to break anything. The only real difference I noticed is the fact that with the MAF disabled my LTFT's on the highway under load (~30% TPS) went to about zero. In the same situation with the MAF on, 1 bank is at 9% and the other is at 11%.
FWIW, I ran across two vehicles today that had bad MAFs (1999 Firebird Formula, 2000 Denali). It's definitely not uncommon.
Can you grab a log with the MAF disconnected? You can disable the max line pressure by checking the transmission DTC Fault Max Pressure Enablers and setting it to No for P0103.
Justin
Old Apr 28, 2009 | 05:57 PM
  #32
GMCtrk's Avatar
My first attempt at a SD tune. Check out this log
File Type: efi
GRRR65GTO
Oct 10, 2015 04:37 PM
726.0chevelle
Sep 12, 2015 09:24 AM
sTNT971
Sep 11, 2015 02:38 AM
cousblake11
Sep 9, 2015 06:52 PM
