So I've got an air leak somewhere
Old Apr 24, 2009 | 06:17 AM
GMCtrk's Avatar
I guess the only good news out of all this is the fact that I really haven't seen the power out of this thing that I should be given a proper AFR.
Old Apr 24, 2009 | 07:01 PM
GMCtrk's Avatar
Well, I sprayed brake cleaner (highly flammable) everywhere and I didn't hear one bit of difference in the idle. My EFI live doesn't do the blackboard (dashboard B) in real time? At one point my STFT's did go to like -10. I'm attaching the log.
File Type: efi
Old Apr 24, 2009 | 08:26 PM
BlackGMC's Avatar
Resident Retard
HUH? i don't understand that.
Old Apr 24, 2009 | 08:27 PM
GMCtrk's Avatar
neither do I. If I switched to display A (the gauges) it reads just fine. Click on B and nothing?
Old Apr 24, 2009 | 08:28 PM
BlackGMC's Avatar
Resident Retard
did you add the Short term trims do the dashboard B?
Old Apr 24, 2009 | 08:31 PM
GMCtrk's Avatar
yes...
what do you make of the log i posted
charcold-bowtie's Avatar
make sure to be recording, not monitoring?
Old Apr 24, 2009 | 08:33 PM
GMCtrk's Avatar
yep i was recording. No activity on dashboard B
Old Apr 24, 2009 | 09:50 PM
GMCtrk's Avatar
Ok, went out again. Got dashboard B working. Had the laptop in the engine bay logging. Sprayed brake cleaner everywhere. Nothing. No change in idle, STFT's remained stable. wtf.
What are normal values for the LTFT and STFTs? Should the LTFT's always be close to 0?
I clearly have a problem as under load on the highway the LTFT's would be between 9 and 11%
Old Apr 24, 2009 | 10:22 PM
budhayes3's Avatar
PT's Slowest Truck
LTFT's should be as close to 0 as possible...
