Smoothing a TBSS intake, vs structural integ??
Baltimore Whore
You have any pics?? This will def get done if I can some how get the wire harness off of it, rerouted some. But from the sounds of what I have been told, that harness is not going to move much, unless I take it out, redo it.. FUKN BUMMER
What smoothing it??? This is just cosmetic.. Unless your talking about porting it..
9 Second Club
Here ya go:
I didnt do much with the harness really, I think I disconnected the map sensor and cut the tie wraps, split the loom to retrieve the map wires to give the extra room for the harness to set on the fuel rail sort of. Like I said, I didn't buzz the ribs, but just doing the little cleanup I did helped A Lot imo, lemme know whatcha think!
Baltimore Whore
That looks fukn fabulous.. If i can get my harness like that I would be happy.. Just hope I don't run into issue with the harness and the blower( since it sits in the driver side fender area) Thanks for the pics.. So the harness moved pretty easy once you popped all the fasteners off the intake that held it.. Thanks again.. Def gives me some thoughts on what to do.. As far as the map goes, did you use the one in the TBSS intake or the one from stock one? Did you change anything in the tune after the intake, other then fuel???
Here ya go:
