Smoothing a TBSS intake, vs structural integ??
Old May 4, 2011 | 06:56 PM
Bama2door's Avatar
Do you think there would be any benefit to doing this to the stock nbs 78mm intake?
Old May 4, 2011 | 07:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by Rhino79
I had mine off and did a mild port job to just the opening, I also ground off all the studs and garbage EXCEPT for the ribs. It should be plenty thick though, from what i saw when I partially cleaned mine up, it was beefy.
You have any pics?? This will def get done if I can some how get the wire harness off of it, rerouted some. But from the sounds of what I have been told, that harness is not going to move much, unless I take it out, redo it.. FUKN BUMMER
What smoothing it??? This is just cosmetic.. Unless your talking about porting it..
Old May 4, 2011 | 07:17 PM
Rhino79's Avatar
9 Second Club
Ill take some now, I did mine and rerouted the harness a bit without cutting it at all besides taking the map wires out of the loom to reroute it. Gimme about 10-15 ill have em up!
Old May 4, 2011 | 07:25 PM
Baltimore Whore
Thumbs up
Beautiful. Also gime some details what you did as far as the harness.. Thanks
Old May 4, 2011 | 07:27 PM
05gmcsierra's Avatar
me wana know also...lol.. i just slapped mine on but its in stock form..
Old May 4, 2011 | 07:44 PM
Bama2door's Avatar
Sorry I meant porting the inside of it...
Old May 4, 2011 | 07:51 PM
Rhino79's Avatar
9 Second Club
Here ya go:
I didnt do much with the harness really, I think I disconnected the map sensor and cut the tie wraps, split the loom to retrieve the map wires to give the extra room for the harness to set on the fuel rail sort of. Like I said, I didn't buzz the ribs, but just doing the little cleanup I did helped A Lot imo, lemme know whatcha think!
Old May 4, 2011 | 07:54 PM
Rhino79's Avatar
9 Second Club
I have debated, prepping and painting those ribs red. I basically used the cutoff wheel and that was it, didn't spend a lot of time with it. But its on my list to do.
Old May 4, 2011 | 07:59 PM
Baltimore Whore
That looks fukn fabulous.. If i can get my harness like that I would be happy.. Just hope I don't run into issue with the harness and the blower( since it sits in the driver side fender area) Thanks for the pics.. So the harness moved pretty easy once you popped all the fasteners off the intake that held it.. Thanks again.. Def gives me some thoughts on what to do.. As far as the map goes, did you use the one in the TBSS intake or the one from stock one? Did you change anything in the tune after the intake, other then fuel???
Old May 4, 2011 | 08:00 PM
2007chevy5.3l's Avatar
Here ya go:
Clean!!
