Smaller Pulley vs Stall
Old Apr 12, 2004 | 02:28 PM
Boosted 6.0's Avatar
Default Smaller Pulley vs Stall
I'm debating on going with a 3.1 pulley for my Radix or 3000TT, any advice?
Old Apr 12, 2004 | 02:38 PM
How could you compare a $800 stall, and a much cheaper pully? Dont have $ for both?
Go with the stall, it will help the most. Better have some DRs or Slicks though.
Old Apr 12, 2004 | 02:43 PM
Stall = new tires= alot more money. How will a stall affect launch on a AWD? Yeah I was thinking smaller pulley cuz it's cheap HP ($100 for 40 horses) and saving up some bread for a rebuilt tranny.
Old Apr 12, 2004 | 04:38 PM
Hit Man X's Avatar
Stall's going to help your hole shot a ton...also help w/ shift extension on the 1-2 shift bridging the gap between the WIDE 1st and 2nd gears.
I'd do stall just for it's drivability, the performance comes along with it.
Old Apr 12, 2004 | 04:54 PM
how will the stall affect my AWD drivetrain???
Old Apr 12, 2004 | 05:41 PM
With AWD, you could get a 3000 stall, and spray a 100 shot out of the hole and get very little tire spin. AWD, you can keep your stock tires with a stall. Just watch for that whiplash.HAHAHA
Old Apr 12, 2004 | 06:02 PM
zippy's Avatar
the awd trucks will still spin if you have a higher stall in them.
Old Apr 12, 2004 | 09:09 PM
Hit Man X's Avatar
If you have enough power and stall, yes you will get wheel spin with AWD...not a lot but some and torque steer too.
If won't effect (or is it affect?) your AWD adversely anymore than the blower did you installed. Instead of launching at a low 1800-2000rpm, you'll be at least around 3000rpm to 3500rpm (dependant on input torque and weight)
Old Apr 13, 2004 | 01:50 PM
Is there any mods I can do to reduce Torque Steer?
Old Apr 13, 2004 | 02:25 PM
zippy's Avatar
e-locker.
1slwgto
Oct 1, 2015 01:51 PM
06 4.8
Sep 11, 2015 10:36 AM
Justin87gn
Sep 10, 2015 12:06 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
