SLP Thermostat for 5.3?
Old Jun 16, 2010 | 09:53 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Jordan927
That's exactly what you do with the tune...you can run a little more timing.
65 bucks is a little steep....especially when you can get one on SDPC for 24 bucks...
$24 has to be the 04+ that is just the t-stat, the 99-03 has the t-stat and housing as one piece, and I doubt that you'll find that one for less than $50.
I've been running a 160* stat for about 6 years now, and I've been happy with it so far, although after some debate in a thread a while back, I've decided to up to a 180* stat the next time around, if I ever have a problem with this one or swap in my LQ9, whichever comes first. Seems the LS engines are their most efficient when running between 180-200* from what I remember from that thread. Stock stat is 194* btw. If you search either 160 stat or 160 thermostat, you should find a multi-page thread that I'm referring to...
Old Jun 17, 2010 | 12:00 PM
Jordan927's Avatar
Not sure if LS1 had a one piece or not actually....the one for 04+ says its 04+ than the other one says LS1/LS6 Both are 34 bucks
Old Jun 17, 2010 | 12:08 PM
nonnieselman's Avatar
Search BB mod.. its free and it works.
I had drilled out the check ball and other little stuff. mine would run right at 175-180.
pewter00
Sep 14, 2015 09:17 PM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
pewter00
Sep 7, 2015 10:14 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
