SLP Cam
Originally Posted by 5.3 racer16
aversi nos miramos en diciembre en el autodromo.
Bilingual bitches! no mas!!
Hahaha I'm 1/2 Spanish and the only words i know are the ones my grandma used to call me when I was little... Cabrone, flocko, and a few others she saved for when I was really bad.
I don't think the cam is going to make much of a difference. You only adding a few deg. more durration which won't change your effective RPM much and the LSA isn't much different either. Lift? Won't even notice it really.
I'm not a cam expecrt though so who knows. I just see tons of cam swaps and unless you go radically different not much is going to change.
Bilingual bitches! no mas!!.
I8AHEMI, 5.3 racer16 let me know when you're here.
Originally Posted by The_Mexican
Can you recommend a better cam? I was also thinking about the comp cam 222/224 .566/.568 112° what do you think about this one?
Originally Posted by Tiburon
Gilberto, you want a cam with nothing less than a 114 lobe seperation angle because of your blower. This is the angle between the intake and exhaust peaks. The lower the angle, the more valve overlap there is causing cilinder preasure blead. I would only a 112 lsa on a N/A motor.
lawhitediamante
Aug 12, 2015 12:14 PM
