single turbo setup ? pics of my project
for all people running single turbo setups. i am building a 92 gmc typhoon with a lq4 and 4l80 with a single turbo, what did you use on your setups for headers or manifolds and crossover pipe .pics and any info would be great, thank you all
link to some pics
http://www.newengland-motorsports.co...ad.php?t=39984
link to some pics
I used the basic KBRacing front mount kit on my lifted k2500. The manifold is nitroplated and is the only piece that didn't need a slight modification or two (mainly my platform difference 3/4ton versus 1/2ton). I use a MP70mm and have full boost (8lbs) by 2800-3000rpm usually. I've ran as much as 12lbs for a week or two and the iats weren't to out of range, but the turbo was maxed oout then basically. The stock lq4 just has valve springs, the 70mm front mount, stock 4l80e, and tune by me.pics are below. Good luck on the project as there are a couple more that were close or are close to being completed also.
http://s486.photobucket.com/albums/r...Turbo%20Truck/
GFYS and STFU
There's a member on here that has a single turbo Syclone, not sure what brand hot parts he was using. But most of us on here use either KBRacing or Trick hot parts. Both of whom are also sponsors on this site!
iregret
Jul 27, 2015 10:32 PM
oharajo
Jul 18, 2015 09:24 PM
