Silverado SS exhaust question
Old Jun 1, 2009 | 11:05 AM
03 BLACKOUTSSS's Avatar
Default Silverado SS exhaust question
I am putting LTs on the SSS when I do the heads and cam. The problem that I have is no one sells a "direct fit" Y pipe for the it. I guess because its not a "Y" pipe, its just two pipes that run from the cats into the muffler. Does anyone know the diameter of this "intermediate piping? I would like to reuse the piping if I can, and just use minimal piping with some flanges to make the final connections. I could measure it if I was in the state, but I would like to order some stuff before I get home. One more question that I have is can I weld flanges onto the collectors if they are coated, or am I better off with band clamps?
Old Jun 1, 2009 | 11:18 AM
budhayes3's Avatar
PT's Slowest Truck
Not sure of your budget, but I believe that StainlessWorks, ARH, and Dyntatech make direct bolt-in systems....
(sorry I couldn't answer any of your questions though...)
Old Jun 1, 2009 | 01:23 PM
Yeah, I know they make systems, but you said it man, I don't have that kind of cheese. Its tough to justify the same amount of money on exhaust as I am spending on ported heads and a cam.
Thanks man.
Plus, I thought about trying to get just the Y pipe from them, but then I thought about alignment issues with the pacesetters. Do you know if I can get away with welding flanges onto collectors that are already coated?
Old Jun 1, 2009 | 01:28 PM
krambo's Avatar
Are you doing this work yourself? If not, a reputable exhaust shop can make short work of mating the headers to the exsisting "Y" pipe for a minimal cost.
Old Jun 1, 2009 | 01:32 PM
Well, I was thinking that I might do it myself. I am not that good at welding stuff in the car, but if I can tack the flanges then remove to finish the welds, I would like to do it myself.
I am also trying to configure the setup in such a manner that it it easy to remove / swap parts / etc... while maintaining good seals without constant tightening of the bolts.
Old Jun 1, 2009 | 08:27 PM
budhayes3's Avatar
PT's Slowest Truck
I'm no welder, but I'd think that you could always hit the area to be welded with a die grinder and "oatmeal cookie" if you had to...hopefully someone with some welding skills can chime in on this...
Old Jun 1, 2009 | 08:30 PM
GMCtrk's Avatar
OBX headers and true duals for $500 on ebay. will bolt right up to your catback
Old Jun 1, 2009 | 08:40 PM
Will I be able to make final connection between the OBX and the stock exhaust?
Old Jun 1, 2009 | 08:49 PM
That is a pretty damn good deal, if my pacesetters weren't arriving tomorrow. I'm a fargin icehole. :doh:
Old Jun 2, 2009 | 04:00 AM
Faze2183's Avatar
lol i wouldnt trust something made for honduhs n such to go on my truck... coughobxcough
LPP LT's imo...
