Silverado brake rotors, do they last?
I have had problems with my 2002 Camaro's rotors warping and I know this is a problem area for Camaros. I'm wondering if Silverado's have this problem as well with stock rotors? Mine is a 2003 reg cab 1500. Thank you for the help!
I have personally had that problem but some guys from the boards say that with the proper care they should be fine. I guess it all depends on how you drive.
Im pretty hard on my truck and warped the front rotors so easily it really pissed me off. Since I have put on wholesaledirect's drilled/slotted stock size rotors and im gonna see how those work. The drills and slots supposidly take away braking power but I can tell you that my truck stops just as good if not better than before and stay cooler too.
I have a 99 Z71 rcsb, and I'm on my 3rd set of rotors in only37K. They didn't warp, just rusted to sh*t. Had them replaced once under warranty about 3 years ago, and just did them again about a month ago, but this time I put on Praise Dyno Pads, Slotted Rotors and E-Brake shoes. Stops great, no noise, very little dust. There is a TSB about installing mudflaps in the rear wheel wells to help keep mud and snow, etc. from splashing on to the rear brake assemblies and causing premature wear/corrosion.
most of the time warping is caused by a hard stop. then sitting at a stop light, heating up more that part of the rotor resulting in warp.
when i stop real hard and come to stop i shift into neutral and get off the brake pedal, then **** into drive when i take off.
