Should I Upgrade My Torque Converter?
Old Jun 5, 2008 | 04:56 PM
jleonard711's Avatar
Default Should I Upgrade My Torque Converter?
I am in the process of building up my Yukon Denali (LQ4 6.0L). It is my daily driver, and I want it to be farily quick on the streets with the occasional track outing (maybe once every 6 months or so). I have already picked out most of my mods, and here is a list of what I already have:
Outlaw Intake (installed)
Corsa exhaust (installed)
e-fan swap (installed)
Long 40K Tranny cooler (installed)
Radix M112 w/2.8 pulley (installing next weekend)
Cam Motion 205/212 548/540 114 cam (installing next weekend)
Comp Cams hardened pushrods (installing next weekend)
LS6 Springs (installing next weekend)
Wester's Tune (installed, but will get retuned after Radix & cam install)
Before I started any of this, I already had my 4L65E transmission rebuilt and reinforced because I wanted to have that done before adding any power to the truck since I've read that the tranny is one of the weak spots when going to forced induction. I had my builder upgraded things like the sunshell, clutch packs, bands, and servos, but when it came to the TC I just had him put in a new OEM one. Was that a mistake, or will I be okay with the stock TC since I'm not going to be taking to the track at all? And I don't plan on really doing any street racing either - just very "spirited" driving.
So do you guys think I'm okay with the stock TC, or is it likely that I'll run into problems with my TC once I get my Radix and cam installed?
Old Jun 5, 2008 | 06:10 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I don't think you'll have any problems like failure but I'd go with a small stall to compliment the cam a bit. Good luck with the install!
Old Jun 5, 2008 | 06:13 PM
Do you know what the stall is on the OEM TC for the 4L65E?
Old Jun 5, 2008 | 06:21 PM
fastrt's Avatar
11 Second Truck Club
mine is like 1800-1900 ish. go with a yank, or trail blazer, maybe 2400- 2600.
Old Jun 6, 2008 | 01:06 AM
Will a higher stall T/C make any difference other than the ability to launch faster? Like I mentioned in my original post, I'm not going to be racing it at all to where I would ever have the need to brake-stall it to get a fast launch. So if I'm not going to be doing that, will a high-stall T/C even be beneficial at all? I can understand maybe upgrading to a more durable unit than the OEM, but what will I gain by increasing the stall if I'm not going to be racing it at all? I'm just basically curious about the longevity of the stock T/C with the additional power; I'm not necessarily looking to get the fastest possible 1/4 mile time or anything like that.
Old Jun 6, 2008 | 12:32 PM
shupe's Avatar
They add to the fun factor. Give it a shot.
Old Jun 6, 2008 | 12:59 PM
SS_bnoon_SS's Avatar
It is absofreakinglutly a good mod for a daily driver. It not only provides better launches, but the RPMs drop less between gears on upshifts and stall higher on downshifts, making it a blast to drive around town, entrance ramps, and stoplights. I LOVE my Yank!!!
Old Jun 6, 2008 | 02:53 PM
RotaryResurrection's Avatar
how do stalls perform on the highway? Are you cruising rpms changed at all from what they would normally be at the same speeds? IN other words, if a truck normally locks at 2000rpm at 70, and you put in a 2600 stall, does the truck still cruise at 2000@70, or somewhat higher?
Old Jun 6, 2008 | 02:59 PM
ForcedTQ's Avatar
Lightbulb
So long as you purchase a torque converter with a locking clutch mechanism, your cruise RPMs will stay the same. That's what the clutch does, locks the TC up so that the engine's crankshaft RPMs and transmission input shaft RPMs match.
Old Jun 6, 2008 | 04:04 PM
zippy's Avatar
My opinion would be to keep the stocker in there.
