Should I get LS1 heads?
Old Aug 30, 2007 | 07:57 PM
usarmyman's Avatar
Default Should I get LS1 heads?
Like the title says. Should I get some LS1 heads for my 5.3? What is the improvement for this head over the stockers? The motor I got is out of a 99 BTW.
Old Aug 30, 2007 | 07:59 PM
nightrunner's Avatar
Mr. Obvious
no
The message you have entered is too short. Please lengthen your message to at least 5 characters.
Old Aug 30, 2007 | 08:16 PM
silver-mod-o's Avatar
Hunt&Fisherator
what casting number?? some LS1 takeoffs with s a litle work normally net you some gains.
Old Aug 30, 2007 | 08:22 PM
Mr. Obvious
wouldnt they need to be milled considerably to bring his compression back up to normal 5.3 status?
if they were worked on and milled, then yes but just slapping some ls1 takeoffs on a 5.3 is not the best combination for NA power. they would probably work pretty good for a FI app. but not NA.
Old Aug 30, 2007 | 08:26 PM
usarmyman's Avatar
So it would be better to just work over the sock units like I origanilyed planned.
Old Aug 30, 2007 | 08:30 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
No.
Yes.
Either go with WCCH 5.3 heads or have yours worked but I would make head work one of the last mods.
Old Aug 30, 2007 | 08:38 PM
Mr. Obvious
Originally Posted by trever1t
No.
Yes.
so true, but...
see his sig, 4.3>5.3 swap, im guessin he wants to build his motor before droppin it in
Old Aug 30, 2007 | 08:41 PM
TouchOfEvil04's Avatar
If you don't want to drop alot of cash i'd get Richard to work yours for you.
If you don't care about the cost that much like myself you should get the Edelbrock 5.3 heads he can build for you.
Old Aug 30, 2007 | 08:43 PM
usarmyman's Avatar
Originally Posted by nightrunner
so true, but...
Thats the plans. I want this thing to be ready to rumble when it gets dropped in. Plus why not get the heads worked wile I have them off. I plan on taking them off to check out the enternals.
Old Aug 30, 2007 | 08:46 PM
usarmyman's Avatar
I am in the Army, so I care about cost.
What should I have done to them. I was planning on a Port and pollish and maybe a shave.
