Should i buy new accessories?
Old Jan 12, 2004 | 09:03 PM
Default Should i buy new accessories?
Well im fixin to start puttin the 6.0 together...all i need is oil pump, timing chain, head bolts, and injectors....i was wanderin if i needed to buy new accessories...i plan to use alot of them from my 5.3 like alternator and water pump...should i buy new ones? and what about coil packs? im assuming i can just take every accessory i need off of the 5.3 and stick it on the 6.0 is this a good idea? thanks!
Old Jan 12, 2004 | 10:00 PM
BigTex's Avatar
Keep all your 5.3 accessories. No need to buy new ones. Your coil packs are fine.
Old Jan 12, 2004 | 10:46 PM
thats what i figured....thanks
Old Jan 13, 2004 | 07:18 AM
Scream's Avatar
MOOBIES Moderator
The water pump is pretty easy to get to, so unless you have 100K plus, I wouldn't consider changing it out.
When you swap the motor, you can pull the alt/ps bracket off to the side, as well as the a/c compressor. We didn't even have to pull the radiator to get my 4.8 out! Good luck with the swap...can't wait to drive mine!
OHsixLS3
Nov 22, 2015 07:45 PM
nabozny21
Oct 17, 2015 07:47 PM
JoshH
Sep 28, 2015 11:19 AM
sTNT971
Sep 26, 2015 04:22 PM
