shorty headers
Old Apr 5, 2008 | 12:19 PM
99gmcoffroader's Avatar
Default shorty headers
i just boght some used pacesetter shorties, I was just wondering, do I have to go and buy header bolts, or will the bolts from the stock manifold work? I went and bought a new gasket from the dealer, just not sure if I have to go out and buy some header bolts. Wnat to have everything together, as I am planning to install tommorrow afternoon.
Old Apr 5, 2008 | 05:36 PM
bluedream02's Avatar
you will be able to use the original manifold bolts but some times you may have to use washers depending on the head size of the bolts and also if your original gaskets are copper you dont have to replace them they work better than any other gaskets. you will need to go and buy bolts for the flanges but again the flange will not need a gasket good luck
Old Apr 7, 2008 | 09:55 AM
AGAMBILL's Avatar
I ran the felpro HP header gaskets and have had no problems. The Heddmans come with new bolts.
Old Apr 7, 2008 | 09:58 AM
LowBlack99's Avatar
Stock gaskets and bolts will work fine.
flatblack83
Jan 3, 2026 07:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
Superman09
Sep 25, 2015 05:55 AM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
