short block swap
Old Feb 14, 2007 | 12:25 AM
Jeff Alexander's Avatar
Default short block swap
soon Im going to get a ls1 Im just going to swap the short block and use all the truck stuff. the only questions i have is, I know you have to use the truck oil pan but what about the oil pump and the oil pick up tube. and would you put new rings and bearings on the motor before swap to freshen her up or just put her in
Old Feb 14, 2007 | 01:59 AM
one more question, Ive been doing some research on head flow. is this right the ls1 heads flow the same as our 5.3 heads so there is no point in put the ls1 head on when i do the swap just use my heads?
Old Feb 14, 2007 | 08:17 AM
quicksilverado's Avatar
Use all the truck parts including the oil pick and windage tray. The 5.3 heads will bump the compression ratio up and make more power.
Old Feb 14, 2007 | 11:15 PM
t.t.t
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
steves86ta
Jul 28, 2015 10:21 AM
Gadgetized
Jul 22, 2015 11:55 AM
