Intake?? Worth it?
I was looking at some of the intakes out there, FAST, LS6... I read some of the posts on here and see that there can be some work involved. For all that have done the swaps, was it worth it? Any suggestions if I am looking into getting one? This is a big area that I am not very familiar with.
if you dont plan on turning well over 6200 rpm i dont think its worth it..i put the ls1 intake on mine..i turn 6800 rpm in my truck though..ill probably be putting either an ls6 or edelbrock intake on mine this summer
it all depends on your setup...it might be worth the effort for a nice build up but for osme it woudlnt be...i run car intakes..it was benefical to me. i had a good connection to get access to all Fbody accessories
If you wanna do it...do it. Most of these guys will try to talk you out of it. But like dirt_track said, if you're not windin it up pretty tight, you're prolly not gonna get alot out of it. They're are very asthetically pleasing though
Chevy High Performance magazine tested the various intakes, on stock engines and engines with several cam profiles. The Big Ugly held up with the best of them, make slightly more power under 6,000 rpm and slightly less over 6,000 rpm (2-3 hp from what I remember).
Originally Posted by tdrumm
With the stock and very small aftermarket cams. When they started putting decent sized cams in them, the truck intake fell behind.
GMCtrk
Dec 18, 2015 04:47 PM
Fast86z
Aug 23, 2015 12:35 AM
