Short Belt
Old Aug 20, 2003 | 10:46 PM
CashDudeHomie's Avatar
Default Short Belt
I have the ASP pulleys so I can bypass the power steering without the belt rubbing but it appears the only way to do this is to bypass the power steering AND the idler pulley under the throttle body. Just wondering if anyone has done it this way and if it would be ok to bypass the idler pulley. Thanks.
Old Aug 20, 2003 | 10:55 PM
Banned
Default Re: Short Belt
i think smokeur5.0 used a short belt setup on his dyno runs i doubt if there would be a huge problem with doing that though, isn't the idea on a short belt to run off crank, alt and waterpump only??? well, tentioner also.
Old Aug 21, 2003 | 02:41 AM
I read that you have to add an extra pulley but it looks like you can reroute it to bypass the idler and power steering pump. I wasn't sure if the idler pulley served any purpose other than to route the belt around the throttle body.
Old Aug 21, 2003 | 02:46 AM
Banned
i don't think it does, it's not hooked to anything is it?
AdaMax
May 16, 2016 11:35 PM
gmcyukon
Oct 5, 2015 06:20 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
