SHIFT POINTS, HELP>>>
Old May 25, 2003 | 12:37 AM
INDIGO 5.3's Avatar
Default SHIFT POINTS, HELP>>>
For those of you that have a 2000-03 5.3L with 3.73 gears, what are your maximum shift points set at? I need to know what MPH your trucks are shifting from 1-2 and 2-3 at wide open throttle. Also what are your rev limiters set at? Right now mine is set to shift at 47mph from 1-2 and from 2-3 it will shift at 89mph. Is that too high or can i do more? Or is that just fine? HELP
Old May 25, 2003 | 11:59 AM
Default Re: SHIFT POINTS, HELP>>>
I have my shifts set for +3 and +11, I also have a 5.3L and 3.73's. I'm not sure exactly what the mph is but I know it lower than yours. My 1-2 shift at +3 is 5984 rpm's and the 2-3 at +11 is 5948 rpm's. I think that's about 44 mph and 84 mph respectivly. If your going up to 47 and 89, either you don't have 3.73's or you truck revs much higher than mine does. I tried the max for mine which is +4 (6112) and +12 (6016), truck didn't like going over 6K, seem to pull less over 6K rpm's.
Jim
Old May 25, 2003 | 02:32 PM
Feed's Avatar
or different size tires
Old May 26, 2003 | 01:59 AM
INDIGO 5.3's Avatar
tire size is 275-60-17 and it does rev higher, shifts at about 6150 around there.
Old May 26, 2003 | 05:29 PM
KeukaZ71's Avatar
mine is set for +3, +10 and my 1-2 shift is around 40-42mph, my 2-3 shift varies, sometimes it is super early, but on a good shift it is somewhere around 85-89
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
