she is down now---really down!!!!!!!!!!!!!
#71
Formerly one92rs
i will have to ask about that.....here are the pics of the leaf spring. if you look closely you can see it bows upwards in the middle. oh and the new caliper paint scheme as well. board.
lemme know what you think. oh yay here is the main culprit besides my foot. it is hiding.
#72
i think you're certainly on to something. i'm not saying your truck isn't making good enough power to break parts, but you're breaking parts at a power level way below what others have been running and not broken a thing. those leaf springs certainly don't look right. i'd look for another set from a 99 (99' leaf springs are 20mm lower than an 00') and add caltrac's to them or build something similar. i'd also recomend getting rid of that two piece heavy *** driveshaft setup. i tihnk with a one piece driveshaft and the pinion angles correct you shouldn't have the tailshaft breaking problem. (something else maybe, but not that, lol).
#75
Your leafs are deffinatly bad, but with a 2-piece driveshaft the pinion angle out of the tranny isnt effected by the rear. The carrier bearing holds the first shaft in its place, but the second could suffer and shimmy acceleration due to the axle wrap.
Why hasnt any one tried some ladder bars on there truck yet? Makes for one solid axle with 0 axle wrap.
#77
Formerly one92rs
yay it does. thanks snakeeater for that tid bit of intfo. that makes great sense as well. i guess i will get some springs while i am at it. man this is beginning to really cost me out the wazzzoooooooo. any body have any info on the one peice driveshaft for an ext cab./
#78
