Service Traction Control..........
Old Jun 6, 2013 | 05:28 PM
Mark Johnson's Avatar
Default Service Traction Control..........
Need some help- one morning I startup the truck, a 2011 Silverado 6.2L and get lights in the dash for ABS and Traction Control. Then in the info center it says that TC and Stabilitrak are diabled and to service them soon. I reflashed to original tune- no help. I disconnected the battery overnight- no help. I looked at all the fuses, everything OK. Anyone else had this problem B4? SOmething I can tap with a mallet maybe.................
Old Jun 6, 2013 | 08:28 PM
BigDaddy0381's Avatar
Wheel sensor? I had an 04 do that and it was a bad front wheel sensor. stock gears? gear changes will throw all sorts of lights and dinging.
Old Jun 6, 2013 | 08:45 PM
Yeah- stock gears; 3.73's even. Hmmm- I was sure it was the tuning, still trying to get my hands on HP 2.24..................
Old Jun 6, 2013 | 09:13 PM
08cheyennesc's Avatar
Check sensor connections if the message appears right after you turn on the truck.
Old Jun 6, 2013 | 09:44 PM
lady3bglover's Avatar
Escalades going through the same thing, see if there's a recall/tsb on it.
Old Jun 6, 2013 | 10:07 PM
THanks guys- I'll check all that out. BTW, where would the sensor be so I can get a look at it................
Old Jun 6, 2013 | 10:24 PM
mag13L9H's Avatar
The 2011 5.3 I had was doing the same and it ended up being a steering wheel position sensor and a wiring harness under the dash.
Old Jun 6, 2013 | 11:08 PM
Take it in and get the code pulled don't start changing parts ***** nilly you'll cost yourself a fortune and still not fix your problem.
Old Jun 7, 2013 | 07:14 PM
Thanks guys- I've got a buddy with a scanner, gonna try and get ahold of that and go from there. To be honest with ya, the brakes haven't felt this good since I bought the truck...................
craigsix's Avatar
i had the same thing after a nite at the track. i usually hold my button at startup to disable traction and stabilitrac. unless its raining. never saw the code again for two weeks now.
