sea foam
Fuel injector/Top engine cleaner. Works great, but have a new set of spark plugs. You just may need them. I seafoamed mine and fouled 8 brand new NGK iridium plugs at $7 each
Sea Foan is good ****. Run it through with a half tank of gas and everything from the injectors down will be clean enough to eat off of. Pour it in the intake a little at a time and let it sit for a while, ten start it back up, and everything else will be nice and clean. This is where you'll produce LOTS of smoke and potentially kill a set of plugs.
Check this thread out from our Impala/Caprice forum:
http://www.impalasuperstore.com/nais...TOPIC_ID=26836
-SS
-SS
