SDPC 5.3 Build
Old Jul 14, 2011 | 06:23 PM
  #81
grey matter 04's Avatar
13 Second Truck Club
any sound clips of this cam?
Old Jul 14, 2011 | 07:46 PM
  #82
12Racing's Avatar
Cody you heard luke C. truck and yes it made 323 not 223
i'll try to get a sound clip and dyno graph. truck dont even lope and is 5.3
Old Jul 15, 2011 | 03:21 AM
  #83
i wanted sound clips of the ht1 214/218 cam from scroggins
we want to run this cam in a buddys truck
Old Jul 15, 2011 | 11:58 AM
  #84
Beau@SDPC's Avatar
Trucks Sponsor
there is a vid floating around on youtube, but it is not the best. I have been meaning to get sound clips of mine, but just have not had the time. We are doing a car show this weekend. I will try to get clips then and get them posted monday!
Thanks!
Old Jul 21, 2011 | 10:43 AM
  #85
Mr.Nobody's Avatar
Originally Posted by 12Racing
my buddy got a 5.3 with 150k miles stock fan with ls6 cam, stock heads,3.42, 32in tall tire, and 2nd gear pull made 323rwhp. on a mustang dyno that reads low.
ive seen them put every single part in and on this motor and its legit and watched it on the dyno. the truck runs like a raped ape! lol
Old Jul 21, 2011 | 12:47 PM
  #86
flippindabird's Avatar
guess im getting a LS6 cam and going to that dyno! Nobody, you should be pissed you spent so much $$$ on your cam
Old Jul 21, 2011 | 02:25 PM
  #87
Mr.Nobody's Avatar
haha i have no reason to be mad bc mine made wat normal cam only 5.3s make, hell i got him beat by 10 horses! im sorry its hard to believe the truck did wat it did.
Old Jul 21, 2011 | 02:30 PM
  #88
well this guy puts better heads and cam on his and is 30 under you 2... seems REAL crazy... any track numbers, id really like to know what a LS6 cam in a 5.3 would run in an otherwise stock ecsb 4x4 would run... cause id swap to a ls6 cam in a heartbeat if itd get my truck in the mid 14s with just cam and custom tune(have cold air kit & magnaflow exhaust installed, electric fans on the shelf)
Old Jul 21, 2011 | 02:45 PM
  #89
Mr.Nobody's Avatar
his went 14.2 before the converter and dyno tune. thats cam, cai, 4.10s, LT, on ss 20's. all the 5.3s ive seen Allan at futral and Geoff at Eps seem to make 320+.
Old Jul 21, 2011 | 04:15 PM
  #90
Beau@SDPC's Avatar
Trucks Sponsor
Dyno numbers can be very misleading. Different setups, different dynos, different methods of smoothing, etc. Even sea level corrected track times are varied. Different tracks, different surfaces, different means of putting power to the ground (trans, gear, tire). No accurate comparison can be made unless done in the exact same means, ie same dyno or same track on the same raceday....
RWHP numbers for this truck can be improved with the addition of electric fans. Also, everyone needs to realize these are a "Stage 1" head, with stock LS1 sized valves and light porting. They are not milled for compression and as such, will rob some torque; and horsepower, as most know, is a mathematical calcuation derived from tq. Also, compression comes out to about 9.5:1 on this setup (same as stock). With a milled .030" head, it would bump it to around 10.5:1 and would produce also better numbers. This is something I may look at in the future, but since I daily drive this truck and use it as truck hauling quads, and a car hauler regularly. I did not want to run the risk of detenation. Therefore, the 86 octane friendly 9.5:1 CR was opted for.
As soon as I get around to installing E-Fans, I will put the truck back on the SAME dyno and see what results we get.
