SDPC 5.3 Build
Old Dec 26, 2011 | 08:49 AM
  #131
Beau@SDPC's Avatar
Trucks Sponsor
Originally Posted by 03WhiteRCLB
What is the rpm range on this camshaft? How do you think it would do in a 4.8?
RPM Range will always vary on application, but the cam is not a torque monster, so don't expect to light the tires up without gears and a converter. Mine pulls well past 6000rpm w/ ported heads, but again, every setup will differ. All in all, I think it would be a great camshaft for 4.8 with some gear.
Old Jan 13, 2012 | 03:49 PM
  #132
03WhiteRCLB's Avatar
I have a stock converter and 3.42 gears. Can you recommend a cam with good torque? This is a 4700lb reg cab long box 2wd. Stock it made 223hp and 221tq at the wheels. I'm running stock size tires also.
Old Jan 13, 2012 | 04:40 PM
  #133
Beau@SDPC's Avatar
Trucks Sponsor
If you plan to stick w/ stock converter and gear, I would look at doing the Comp 212/218 High Lift (.558/.563) on a 115. It will not have near the dead spot as our 214/218 on a 111.
Old Jan 13, 2012 | 07:29 PM
  #134
Thanks, what should I use for valve springs and pushrods?
Old Jan 16, 2012 | 09:39 AM
  #135
Beau@SDPC's Avatar
Trucks Sponsor
LS6 Springs will work just fine, and I would use Manley push rods. We sell and stock both.
Thanks!
Old Jan 16, 2012 | 09:42 AM
  #136
Beau@SDPC's Avatar
Trucks Sponsor
Quick update. Put the truck back on the rollers Saturday. Only change since the last dyno of 292rw/290tq was E-fans.
Old Jan 16, 2012 | 11:45 AM
  #137
1FastBrick's Avatar
Custm2500's Rude Friend
Nice respectable gain!!! Thanks for the update!!!
Old Jan 16, 2012 | 04:42 PM
  #138
Beau@SDPC's Avatar
Trucks Sponsor
Thanks! It'll make a legit 300rw pull someday.
3.90s will make their way in soon, dropping rwhp dyno #s, but then a Powerbond 25% UD Pulley should even things up. Hoping the gears eliminate some of the dead spot and net a mid 15 in 4000' of air. This pig needs a diet and a converter!
Old Jan 16, 2012 | 07:11 PM
  #139
1FastBrick's Avatar
were do feel the dead spot???
Old Jan 17, 2012 | 09:23 AM
  #140
Beau@SDPC's Avatar
Trucks Sponsor
Under 3k. Of course, it is a full weight CCSB with ported, big valve heads and a 111 LSA camshaft.
