Scored again
Old Jul 12, 2009 | 03:38 PM
SSlow 4.8's Avatar
Originally Posted by JoeGibbSilverado
yes, pretty much a 5.3 with headers and tune, stock cam and converter, 14.20s, ran last night in the 14.5s
oh a converter too? that makes more sense... ya you're pretty much right in line. You race at a little higher elevation or hotter weather generally?
Old Jul 12, 2009 | 07:07 PM
JoeGibbSilverado's Avatar
nope stock converter sslow
Old Jul 12, 2009 | 07:14 PM
StrokerAce03's Avatar
is this the l33 5.3?
If its out of an Envoy I believe its a LM4; which is just an aluminum 5.3. There's no other differences between it and a regular 5.3 other than block material. To bore it to LS1 spec you might have to get it sleeved which cost an arm, half a leg, and a kneecap.
Although if it does have 799 heads then maybe it is an L33? Check to see if the pistons are dished or flat tops.
Old Jul 12, 2009 | 07:18 PM
BlackGMC's Avatar
Resident Retard
If it is the all aluminum with 799 (243) then it is high output one.. i believe it is 9.9:1 unlike the regular 5.3. Nice score
Old Jul 12, 2009 | 07:19 PM
hirdlej's Avatar
I don't think there's enough meat in the cyl walls on the alum 5.3l to make it a 5.7l......
Old Jul 12, 2009 | 07:25 PM
00Silv4.8's Avatar
what happened with the 6.0??
Old Jul 12, 2009 | 07:26 PM
i havent tore it down yet, but it is aluminum with 799 heads, i sure hope it can be brought out enough to a 5.7
Old Jul 12, 2009 | 07:27 PM
it was busted, right under the number 1 cylinder
Old Jul 18, 2009 | 01:09 AM
black06's Avatar
I thought the all aluminum envoy/TBlazer 5.3's came with the older 5.7 ZO6 heads?
xxloudogxx
Sep 28, 2015 12:30 PM
jmarkway
Jul 18, 2015 09:23 PM
KB
Feb 16, 2008 09:08 PM
TurboGibbs
Oct 26, 2006 02:45 PM
