RPM's
Old Oct 24, 2005 | 10:25 AM
JimS's Avatar
Default RPM's
I hear others talking about shifting at 6300 and higher but my motor is just dead after 5600. That's where the shift point is set but even if I shift manually there is just nuttin left after 5600. Completely flat, no pull, no energy at all. Is this normal?
Is this the stock valve train reaching max spin? Is it possible/probable that Nelson left a rev limiter program in the computer? Whaddya think??
Last night I ran to 6k and then got a SES light. Advance Auto read the code and says it's an 02 sensor, left bank. Now what?
Old Oct 24, 2005 | 10:42 AM
white1's Avatar
Put......BIG.....cam......in.....it If its possible to spin to 6k, the rev limiter isn't your problem. What engine is in it? 4.8, 5.3, 6.0? I think my rev limiter is set at 6500, and it pulls hard all the way there.
Old Oct 24, 2005 | 10:52 AM
Fogle07's Avatar
when mine was stock it pulled all the way to 6300. thats what i had it set on in the diabo tuner
Old Oct 24, 2005 | 11:17 AM
Mangled03gmc's Avatar
Baltimore Whore
I have mine set at 6100 and Mine pulls hard all the way up to that.
Old Oct 24, 2005 | 11:21 AM
white1's Avatar
Have you ever floated a valve? If so you probably need new springs. Or has it always been this way?
Old Oct 24, 2005 | 11:24 AM
Deckhand's Avatar
If you have stock cam and valvetrain, then 5600 is good. On the dyno I pulled it to 6700 and it made power all the way up to there. I have my shiftpoints at 6400rpms though.
Old Oct 24, 2005 | 12:50 PM
Fogle07's Avatar
ive never floated a valve. i got a nelson tune now and i shift at like 6100 and it pulls all the way there.
Old Oct 24, 2005 | 02:18 PM
white1's Avatar
I wasn't insuinuating (sp) that you would float a valve reving that high, but if you over rev one and do float a valve, it usually wont pull hard in the upper rpm range. Didnt mean to confuse
Old Oct 24, 2005 | 02:27 PM
Fogle07's Avatar
i know what you mean, i am lucky that i never did float or even break a spring with the 212/218 cam in it.
Old Oct 24, 2005 | 04:27 PM
JimS's Avatar
Pulls real hard right up to 5600 then completely flat. Nuttin. Dead.
