roller rockers
Old Dec 1, 2004 | 05:12 AM
one03sierra's Avatar
Formerly one92rs
Talking
the slp ones are the ones i am using. maybe they are confused. im positive they will work.
Old Dec 1, 2004 | 11:33 AM
CALLED SLP TODAY THEY SAID 1.85s WILL NOT WORK ON 6.0 BUT THEY COULDNT TELL ME WHY HE WAS DICK ANYWAY
Old Dec 1, 2004 | 12:06 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
valve to piston clearance? Just guessing.
Old Dec 1, 2004 | 02:31 PM
mattrem's Avatar
I have 1.8 Harland Sharp on my 6.0, they even fit under the stock valve covers.
Old Dec 1, 2004 | 02:33 PM
Yelo's Avatar
1.85's will work on LQ4's but not on LQ9's....it is a P-to-V clearance issue due to the flat-tops that are in the LQ9. As far as I know 1.8's will work on both motors
Old Dec 1, 2004 | 02:44 PM
marc_w's Avatar
That's interesting... I never heard that about the LQ9's... Is that with factory cams, or aftermarket?
I'm looking to run 1.89's on my .530 cam... on a higher compression head setup.
Old Dec 1, 2004 | 02:51 PM
Yelo's Avatar
I *think* it is with any cam over .550 lift....I read that info quite a few months back when I was looking at 1.85 rockers so i'm not 100% certain on that lift number but I know I'm pretty close
So, actually the 1.85's WILL work with the stock cam in the LQ9...but you WILL have to upgrade springs
Old Dec 1, 2004 | 02:52 PM
mattrem's Avatar
So if I use my 1.8 rockers with the 047 Vinci Cam I am going to have a problem? With that combo the lift will be about 551. I have never heard this before.
Old Dec 1, 2004 | 03:15 PM
Yelo's Avatar
I said I was not 100% certain on the exact lift number.....
The problem is because if the flat-top pistons that are used in the LQ9.....no other LS1 truck motor comes stock with flat-tops, all of the guys running big-lift cams have to fly-cut flat-top pistons to clear the valves, on a stock non-flat-top piston there is ~.200 of relief cast into the piston so valve clearance isn't an issue
Old Dec 1, 2004 | 09:01 PM
put some clay on the top of the piston and gently roll it over...then you'll know how much p/v clearance you got...and if it stops and wont roll anymore, you aint got no clearance
