roller rockers
I *think* it is with any cam over .550 lift....I read that info quite a few months back when I was looking at 1.85 rockers so i'm not 100% certain on that lift number but I know I'm pretty close
So, actually the 1.85's WILL work with the stock cam in the LQ9...but you WILL have to upgrade springs
I said I was not 100% certain on the exact lift number.....
The problem is because if the flat-top pistons that are used in the LQ9.....no other LS1 truck motor comes stock with flat-tops, all of the guys running big-lift cams have to fly-cut flat-top pistons to clear the valves, on a stock non-flat-top piston there is ~.200 of relief cast into the piston so valve clearance isn't an issue
