Rocker install need help.
Old Nov 21, 2004 | 11:40 AM
mattrem's Avatar
Default Rocker install need help.
I am installing Harland Sharp 1.8 on my 6.0, I checked the preload and it came to 2 turns to get to 22 ft.lbs. I added the comp 918 springs and it is 2 and1/4 is this ok or do I need shims?
Old Nov 21, 2004 | 12:57 PM
silent1's Avatar
2 turns is the absolute max you want to go. I'd definitely use some shims. When I used the 1.7 Harland Shaprs they went just under a 1/2 turn for 22ft/lbs. Try to keep them in the 1/4 to 3/4 turn range for best lifter life. 2 turn I believe comes out to .060" pre-load.
Old Nov 21, 2004 | 05:07 PM
mattrem's Avatar
I put it together and started it, runs fine but, now it has a small tap on the left side almost like one may be hitting the valve cover, they all cleared the heads fine. Could too much preload cause this tapping?
DrX
Aug 19, 2015 04:45 PM
nickpc82
Aug 10, 2015 09:08 AM
BigEd_72455
Aug 8, 2015 07:37 PM
N/ALS1
11
Jul 13, 2015 10:56 PM
