rocker arms
the stock valvetrain in all LS1/LS2/LS6 type engines is non adjustable, you just torque down the rocker arm bolts to around 20 ft lbs. If nothing else is changed the stock style non adjustable is fine. But alot of people have problems with after market cams and higher ratio rocker arms on these engines. If your looking for more lift the general consensus is to just get a new cam.
the stock rockers should do you just fine...noticed your from dumas..gotta buddy his gf used to live there and he used to go over there alot and do some racin..it was 2000 chevy ext with a cam and sprayed 4.8 its blue and the lower part was silver had chrome kmc wheels..his name is poncho..said hes raced a supercharged truck from dumas
