Rings are blown, 6.0 time need help
Old Apr 26, 2004 | 12:02 AM
  #21
parish8's Avatar
single digit dreamer
rated at 300fwhp, they have been known to dyno in the 290rwhp range and that is thru 4l80e trannys and tcases most of the time too. seems like i dyned 290 with a cut out and udp intake.
Old Apr 26, 2004 | 12:03 AM
  #22
bigguy75inches's Avatar
so there is only like a 10-20 hp difference from the 5.3? is it really worth the swap?
Old Apr 26, 2004 | 12:04 AM
  #23
i just want a good daily driver thats fast, and can still pull a trailer .
Old Apr 26, 2004 | 12:09 AM
  #24
LQ9 is very underated at 300hp,with a cam and headers it should make about 330rwhp.Add the Whipple and you are at 400+rwhp.
  #25
also,, for the guys who have done the 6.0 swap,,, do i have to tear teh whole front end off my truck,, or can i remove teh 5.3, install the tranny without troubles?
Old Apr 26, 2004 | 12:16 AM
  #26
You only want a 01 or newer 6.0 so the transmission will boltup.If the 6.0 came with a 4L80E transmission you remove the flywheel and spacer and bolt on your flywheel to make everything line up.
Old Apr 26, 2004 | 06:32 AM
  #27
parish8's Avatar
i would say there is more like a 30-50hp diference between a 5.3 and lq4. then theroreticly the 6.0 should respond to mods better too.
Oobray
Jun 13, 2022 03:38 AM
JordanH
Aug 8, 2015 07:59 PM
Dezert1500
Jul 30, 2015 02:51 PM
dantheman1540
Jul 29, 2015 04:45 PM
Gadgetized
Jul 18, 2015 02:15 PM
