Riddle me this...riddle me that...WHAT THE HELL IS TAPPING IN MY VALVETRAIN??
Old Dec 1, 2005 | 08:36 PM
mattrem's Avatar
Most likely you won't have a problem. May sound like a sewing machine, may not. Just make sure your preload is rite and you will be fine. LSX type motors have some valvetrain noise, its just its nature.
I would definately get some better pushrods, those stock ones are weak. Get a good set of hardened ones since you are changing springs.
Old Dec 1, 2005 | 08:47 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
We will welcome you with open arms to the sewing machine club
Nothing wrong with it just the damn sound that they make
Old Dec 1, 2005 | 08:48 PM
vanillagorilla's Avatar
I vote for the lifters! Before you sell the farm though, there is an oil additive that will pump lifters back up. While working on my dad's fleet I came across lifters that were collapsed. The truck wouldn't pass emissions, it ticked and ran like poop. I put the oil additive and it was all good. It was a long time ago and I can't remember the name of it for the life of me. I think all it really did was thicken the oil. It's a temporary fix that could buy you some time until you can get in there and change the lifters.
Old Dec 1, 2005 | 09:05 PM
1slow01Z71's Avatar
IE until the LQ9 gets in there. If you go to a thicker oil it might help also. I forgot about the additive its by the stuff that you put in oyur tank to pass emissions and all that other BS.
Old Dec 1, 2005 | 09:11 PM
Yellowsierra's Avatar
Originally Posted by TarheelZ
Forgive me for temporarily 'jacking the thread, but I'm curious about this issue. Pretty soon I'll be having a pair of mildly worked stock heads (shaved .005) installed along with a mild Lunati LS1 cam, and the Lunati springs. For budget reasons, I'm staying with the stock rockers and pushrods. What's the likelihood that I'll have similar issues with valvetrain noise?
You should be ok if you use the stock pushrods and shaved .005" heads because you usually want to get a little longer pushrod with a bigger cam.
Old Dec 1, 2005 | 09:27 PM
TarheelZ's Avatar
If I do jump for the new pushrods, what length and brand should I get?
Old Dec 1, 2005 | 09:45 PM
1slow01Z71's Avatar
7.400" is what I would go with since the heads have been shaved a little bit already. Pick a brand they are pretty much all good big name brands are comp and thungder racing.
Old Dec 1, 2005 | 11:44 PM
I switched from 5w30 to 10w30 valvoline and that solved my post cam oil consumption issue also.
Old Dec 2, 2005 | 12:24 AM
Thunder, I would try some 10w40 oil with lucas to see if it will quieten the lifter. If you dont notice a change, it might not be the lifter. If you're positive it isnt springs or rockers, it would almost have to be.
Old Dec 2, 2005 | 08:58 AM
thunder550's Avatar
High on diesel fumes
OK thanks guys I will do that. I don't think there's much point to fixing anything in the 5.3 since I am hopefully within a month or two of pulling it out and being done with it, so I will try the thicker oil or the oil additive. Hopefully that will solve the problem. I guess I will add a new set of lifters to the list of parts for the new motor though. Are there better ones out there or would I be just as well off with another set of stockers?
