Rewiring the Traction Control switch/light
Old Jan 17, 2005 | 10:42 PM
Mr. Sandog's Avatar
Default Rewiring the Traction Control switch/light
I'd like to rewire the TC switch/light so the light on the dash panel lights up when traction control is ON, not OFF, like it does now. Has anyone ever done this? I could probably figure out how to do this myself, but I figure if someone else has already done it....
Old Jan 17, 2005 | 11:37 PM
eurosys's Avatar
Mine lights up only when is ON.
Old Jan 17, 2005 | 11:41 PM
Mr. Sandog's Avatar
Mine is always on unless I turn it off....it comes that way from the factory. When I turn it off, there is a light on the dash with the letters "TC" inside a circle, with a line through it, indicating that I have turned TC off. I can set it so it is always off, but that damn light stays on, which bothers me.
Old Jan 18, 2005 | 12:21 AM
eurosys's Avatar
I think yours is working the opposite way. Have it check at the dealer.
Old Jan 18, 2005 | 12:25 AM
Mr. Sandog's Avatar
No, it is working properly.
Old Jan 18, 2005 | 04:34 AM
black_yukon's Avatar
Mine works just like NakedAV's. I set it up so that the default is in the off position, so the light is always on. I think that maybe the SUV and AV might have a different setup than the trucks.
Old Jan 18, 2005 | 08:12 AM
smokeydoge's Avatar
How the heck to you make it default OFF. Mine is on until I turn it off, then it shows the TC with the line thru it...
Old Jan 18, 2005 | 09:57 AM
Mr. Sandog's Avatar
There's a procedure in the manual, it's like 10 steps, you turn the key on and press on the brake pedal and push some buttons....pretty humorous if it wasn't so involved, it's almost like voodoo....
Old Jan 18, 2005 | 09:59 AM
Mr. Sandog's Avatar
Does that light bug you or are you used to it?
Even if I get used to it, I don't want passengers asking, "Is there something wrong with your truck?" That's why I want to rewire it.
Old Jan 18, 2005 | 10:18 AM
moregrip's Avatar
what a rush!
Diagonal cutters
