retsell's HUGE radix heat exchanger
Old May 19, 2004 | 11:16 PM
retsell's Avatar
Default retsell's HUGE radix heat exchanger
Here are some pics of my massive heat exchanger, keep in mind it goes all the way to the bottom of the bumper.
I will find the ones with the grill on the truck tomorrow.
Old May 19, 2004 | 11:20 PM
moregrip's Avatar
what a rush!
holy **** dude, what are your IAT's? and do you have a CDT hooked up?
Old May 19, 2004 | 11:22 PM
moregrip's Avatar
what a rush!
and did you upgrade the pump?
Old May 19, 2004 | 11:25 PM
retsell's Avatar
The other day when driving in 70 degree weather they were 85 (normal driving) under hard acceleration up to 130 mph they got up to 128.
CDT???
I did not replace the pump, it moves enough although I am sure it could be better...
Old May 19, 2004 | 11:28 PM
moregrip's Avatar
what a rush!
Compressor Discharge Temp, i.e. (after the S/C rotors/intercooler).
Old May 19, 2004 | 11:31 PM
retsell's Avatar
Compessor Discharge Temp, i.e. (after the rotors).
The IAT sensor is after the rotors. Part of the radix kit comes with an IAT sensor in the lower tub after the intercooler. You cut the wires for the IAT in the MAF and hook them to the new sensor.
Old May 19, 2004 | 11:34 PM
moregrip's Avatar
what a rush!
that is very cool, thanks for the 411.
what did you use to get the IAT measurement? gauge?
retsell's Avatar
Autotap, that's where I got the MPH from since the speedo only goes to 110
Autotap is god.
Old May 19, 2004 | 11:35 PM
moregrip's Avatar
what a rush!
also it would be cool to have an IAT sensor prior to the intake/blower and compare the temps.
Old May 19, 2004 | 11:37 PM
retsell's Avatar
Yeah, I wonder if I could hook that up to something else... or rather, put a button inside that would kick a relay that would momentarily switch back to the MAF sensor reading so you could get an idea. That may throw off the computer though.
