resetting the computer????
Old Feb 2, 2003 | 02:32 PM
BigTex's Avatar
Default Re: resetting the computer????
Turn the key to "on", but not started. Pull the ECM-A and ECM-I fuses in the underhood fuse box. Put them both back in, at this point you should hear the fuel pump pressurize the fuel rails. Turn truck off - you are done.
Old Feb 2, 2003 | 10:52 PM
JSmith's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigTex:
<strong> Turn the key to "on", but not started. Pull the ECM-A and ECM-I fuses in the underhood fuse box. Put them both back in, at this point you should hear the fuel pump pressurize the fuel rails. Turn truck off - you are done. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I thought it was ECM-B and ECM-1? This must be another way to do it? Usually I turn my key to the run position, the pull the two fuses that I mentioned, let it sit for 5 minutes, turn the key off, re-insert fuses and start the truck. It seems to work for me that way.
Old Feb 3, 2003 | 12:00 AM
CashDudeHomie's Avatar
When would I want to reset the computer?
Old Feb 3, 2003 | 12:53 AM
Dr. Checkup's Avatar
Default resetting the computer????
How do you reset the computer for a 99 Sierra 5.3L. Can't remember what fuses to pull, for how long, if you need to set the parking brake??? you know the same ol' questions everybody ask...
Old Feb 3, 2003 | 05:41 AM
BigTex's Avatar
I may have the A / B mixed up, but the other is an I not a 1. Its been since last march when I gor LS1 edit that I stopped resetting ses lights.
Old Mar 24, 2015 | 10:17 PM
freide05125's Avatar
Registered User
hi i have a 1999 chevy silverado that i just put in a new computer but know it wont star with my old it stars but i still have a missfire on cylinder 4 i took it to gm the work on it replace coil packs spark plugs and all that goes along those lines so i was told to replace computer and i did but like i said it wont star is there a way that i could reset the computer so that the car can reconice the new divice pls help any one to much money in and im about give up the gm said that i have to have computer program they will do it but i have to pay 180 is there away around this
Old Mar 24, 2015 | 10:23 PM
FFDP's Avatar
Where did you get the PCM?
Is it a computer that needs to be programmed to have the 99 file on it or was it a computer that was already in another truck??
You could try a security relearn, sometimes that needs to be done because of the PK3 keys.
Old Mar 24, 2015 | 10:24 PM
BlackGMC's Avatar
Resident Retard
Lol... 12 year old thread bump. That has to be a record but at least you used the search!!
RustyD
May 23, 2016 07:04 PM
Cammed4ever
Sep 30, 2015 03:38 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
supershift67
Sep 18, 2015 08:21 PM
Pimpinpete
Sep 8, 2015 07:39 PM
