Replacing Coolant Overflow
Old Jun 25, 2008 | 10:21 PM
ZZebes's Avatar
Default Replacing Coolant Overflow
I have been doing some snooping on some other boards and have noticed that alot of the GTO guys are getting rid of there stock coolant tanks and using like a 1.5qt CSR can instead, i was looking at my engine bay and it would REALLY Clean up the underhood
What do ya'll think if i ran a T-Fitting in the Return Line for the Heater Core and put a CSR 1.5qt Coolant overflow in the corner of the engine bay behind the headlight or up on the firewall near the A/C
Old Jun 26, 2008 | 10:10 AM
ZZebes's Avatar
Bueler....Bueler...
Something Like this
Old Jun 26, 2008 | 11:29 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
chirp... chirp...
The Corvette resies look awesome in our trucks.
Old Jun 26, 2008 | 11:38 AM
ZZebes's Avatar
Originally Posted by trever1t
chirp... chirp...
I was thinking about that and i have one but if i used this resevoir than i can have more room for a bigger snail later
Old Jun 26, 2008 | 12:40 PM
trever1t's Avatar
Mark (04Denali) had one, it sat far enough back not to interfere with the turbo at all. If you don't use it, bring it with you, i will take it off your hands.
Old Jun 26, 2008 | 06:18 PM
ZZebes's Avatar
Anyone have any input
Old Jun 27, 2008 | 10:19 AM
ZZebes's Avatar
Bueler... Bueler....
COME on even theory works for me now
Old Jun 27, 2008 | 10:47 AM
Bill Reid's Avatar
Do you have the passenger rear corner (Aux Battery area) reserved for something? If not Trick's tank would look good there.
Old Jun 27, 2008 | 10:53 AM
ZZebes's Avatar
Yeah i was thinking that but the reservoir needs some kind of vent and the trick tank is not setup for coolant usage
Old Jun 27, 2008 | 11:55 AM
Bill Reid's Avatar
... couple of mods and I think it would work. I have been considering a metal coolant reservoir because the stock plastic one starts to turn a nasty yellow over time. If I do a metal tank I will move it back to where the Aux Battery would go. I am going to a water cooled turbo soon so I may change the reservoir at the same time so I only slice and dice hoses once...
