removing rev limit and speed limit
Old Sep 24, 2005 | 11:21 PM
99Silver6.0's Avatar
Originally Posted by 5.3GMC
what about hp tuners? i was looking into one of those, and good feedback.
HPTuners is a tuning suite. Its not a tuning company or individual tuner. Thing about HPTuners, FlashScan or LS1Edit is you have to know how to use it. And its best to have a wideband to tune with or you wont ever get AFR dialed in.
Old Sep 24, 2005 | 11:44 PM
5.3GMC's Avatar
can you give me some more info?
Old Sep 25, 2005 | 12:01 AM
All the skinny on HPTuners can be found here http://www.hptuners.com/
Old Sep 25, 2005 | 10:48 PM
lotzafun's Avatar
If you go with HP Tuners, you can change the speed and rev limits yourself, has a help section built into it that shows you how to change it. That is if you want to do it yourself. How much tuning were you wanting to try and do yourself?
Old Sep 26, 2005 | 01:03 PM
Steve Bryant's Avatar
LS1 Tech Veteran
A couple of cautions should be considered:
1. If you change the RPM limit above about 5,800, seriously consider getting some hardened aftermarket pushrods. The pushrods are a weak link in the drive train chain and a bent pushrod is not a good thing. Also, if you merely up the RPM limit and don't have a different cam setup, you are entering the zone of diminishing returns. I believe that the peak HP on the 5.3 is about 5,200 RPM's and going beyond that will just diminish performance.
2. Buying scanning/tuning software is a good way to go, but you need to be committed to learning on a new level. Just tweaking some of the settings and downloading a new tune can be pretty easy. However, to keep you and your vehicle safe, you need to learn what settings to adjust, why they should be adjusted, etc. I have had EFILive with FlashScan for over a year now (I am one of the Beta Testers). Tuning electronically is a lot of fun, but it's also challenging. EFILive/FlashScan are extremely easy to use and extremely capable. No matter whether you use HPTuners, LS1 Edit or EFILive, there's a lot to be learned.
All my best,
Steve
1979rs/z28
Sep 23, 2015 08:39 AM
fastjweb
Aug 15, 2015 10:47 AM
shupe
Aug 5, 2015 06:45 PM
walledition
Jul 29, 2015 08:54 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
