remove intake evap?
Old May 2, 2018 | 09:52 AM
Alaska6.0SS's Avatar
Default remove intake evap?
Has anyone or can you remove the valve cover evap(or whatever its called) to the intake? after removing my intake for a rebuild it was bad inside. like a 1/4 of oil.
Also anyone know of a hidden possible vac leak area on the intake itself, I have LTFT asking 20% on bank 2 or could this be a long tube header issue that is tacked in for tuning. sprayed water around intake gasket nothing, swapping o2s today to check but the log looks good.?.
Thanks
J
Old May 2, 2018 | 10:41 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Year of the truck or vehicle???
It could still be the intake gasket. They dont always leak on the top side.
Old May 2, 2018 | 10:42 AM
1FastBrick's Avatar
The valve cover to intake is a PCV. Some guys run to a catch can to collect the oil.
Old May 2, 2018 | 10:50 AM
2008 suburban 6.0 2500 4x4
Old May 2, 2018 | 10:53 AM
1FastBrick's Avatar
Then likely not the intake it self unless it's been off before.
It is possible the header is sucking in air on that side if you have a leak.
If it sat for a long period of time it's possible the injector's maybe clogged limiting fuel flow..
Old May 2, 2018 | 11:06 AM
Im studying the the log a bit here.... looks like all the fueling data is constitant on both banks its just calling for more, the o2s are from the original manifolds. I started the burb with open headers and the O2 were going insane. I have a ls9 cam and the pacesetters longtubes 3" on a really good tune. The o2 data looks constistant but every once in awhile the bank 2 drops to 45 and bank 1 holds in the 830s. Then the fuel trims almost reset to normal then jump right to the 15-20%. I did have a bank 2 lean DTC code pop once, and is in history but not sure if its from open header start. I did clear it but it hasn't pop the code. the o2 swap is happening today (fingers crossed)
Old May 2, 2018 | 11:08 AM
I like the catch can idea. what a mess. I can only imagine the toll it takes on the life of a motor.
J
Old May 2, 2018 | 11:25 AM
1FastBrick's Avatar
Sounds like the 02 might be going bad.
Tootall
Sep 28, 2010 08:54 PM
Low_LSX
Nov 9, 2009 09:37 PM
BlackGMC
Apr 2, 2009 12:30 AM
Raffman
Aug 26, 2008 01:03 PM
