Removal and reinstallation of Vinci/Crane 1.8 rockers
Old Oct 9, 2005 | 11:03 AM
thunder550's Avatar
High on diesel fumes
Default Removal and reinstallation of Vinci/Crane 1.8 rockers
I am going to R&R the rockers on the driver's side today to try and remove the tapping noise I am getting....will I need to go through the entire process again of bleeding down the lifters and everything, or will it be sufficient to just remove them and re-torque them to a certain spec? I know 22 ft-lbs is the torque spec on the factory rail-type rockers...is it the same for the stud-mounted ones as well?
Old Oct 9, 2005 | 04:33 PM
thunder550's Avatar
Nevermind it's done.
Old Oct 9, 2005 | 06:18 PM
WhiteChevy3's Avatar
did you get that prolblem solved??
Old Oct 10, 2005 | 02:12 AM
thunder550's Avatar
Yep, two of the studs had backed out of the head part way and one was tapping against the inside of the valve cover. Put some loc-tite on and cranked em back down, ticking is gone now.
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
