Removal and reinstallation of Vinci/Crane 1.8 rockers
High on diesel fumes
I am going to R&R the rockers on the driver's side today to try and remove the tapping noise I am getting....will I need to go through the entire process again of bleeding down the lifters and everything, or will it be sufficient to just remove them and re-torque them to a certain spec? I know 22 ft-lbs is the torque spec on the factory rail-type rockers...is it the same for the stud-mounted ones as well?
KINGCYCLES
Oct 2, 2015 10:21 AM
