relocate IAT sensor?
#21
you have to spray meth before the IAT sensor. Its not fooling anything. Its actually a better rep of tru temp. Pour finger nail polish on your hand. feels cool huh?
#24
I wonder if a good rubber grommet installed into the hole drilled in the EGR block off would work and not leak? I have a nice rubber grommet assortment.
#25
Is that a good price? Is the "breakout harness" a 2 wire harness with IAT connector? Sounds like a plug and play deal...could you PM me that info?
#30
Which side of the throttle blade is the EGR on? Because mine is in the intake tube before the TB it is not subject to high vacuum. I doubt that would be a problem but it would not hurt to monitor it when idling to make sure it is not leaking. I think the older camaro 1996?? had an IAT sensor in the intake manifold mounted in a grommet.
The sensor I am using came from a 96 camaro.
